Bluetooth connected Samsung U Flex works fine under windows - tried it, to see if problem was with the headset. Works fine with Android cell phone. SO both voice and sound.
Trying them on Ubuntu 18.10, sound is good (almost perfect)…but the sound from microphone doesn’t get through… So no possibility to make calls with them
Any idea ?
W
Given the attention this got... Seems I'm the only one with UM that doesn't recognise the Samsung UFlex input... Still looking for a solution. WIth UM 21.04 now.
Hi @Watford
LTI - Long time issue xD
Did you try different bluetooth audio profiles ?
I tried everything I thought possible.
But it really seem that it is an issue with switch between HSP/HFP and A2DP profile. The Bluetooth headset does (on other systems) but can't with blue-man on UM.
If EVER I do find a solution, I'll revert here.
