Hi all,
finally I got round to looking at the first update to 16.04 LTS, which is supposed to be a better version than 16.04 on all accounts. However, I seem to have come across a scenario where the opposite is the case: Bluetooth.
My system is a Thinkpad T510, it comes with an integrated Broadcom Bluetooth device. My main OS is still Ubuntu MATE 14.04, but I have a second partition with plain Ubuntu (15.10 currently), because I needed a more recent kernel at one point in the past. My intent is to pair the Bluetooth device with a Logitech BT Audio adapter attached to my Stereo equipment for better sound quality.
The pairing worked on 14.04, but I was unable to redirect the audio output to BT, the BT device just did not show up as a target. I blamed that on the early days status of UM 14.04 and tried 15.10. Sure enough it worked and thus seemed to back my theory.
Now I tried UM 16.04.1, booted from a DVD in “try out” mode. It did not work in the sense that it did not detect the Logitech for pairing. I tried the original 16.04, and to my surprise it worked. So I went back to 16.04.1 and tried to analyze the cause of the problem. I gathered all the entries from syslog that have “bluetooth” in them. Here they are:
Dec 13 10:28:10 ubuntu-mate systemd[1]: Starting Bluetooth service…
Dec 13 10:28:10 ubuntu-mate bluetoothd[3946]: Bluetooth daemon 5.37
Dec 13 10:28:10 ubuntu-mate systemd[1]: Started Bluetooth service.
Dec 13 10:28:10 ubuntu-mate systemd[1]: Reached target Bluetooth.
Dec 13 10:28:10 ubuntu-mate bluetoothd[3946]: Starting SDP server
Dec 13 10:28:10 ubuntu-mate kernel: [ 5.854391] sda: sda1 sda2 < sda5 sda6 >
Dec 13 10:28:10 ubuntu-mate kernel: [ 5.854960] sd 0:0:0:0: [sda] Attached SCSI disk
Dec 13 10:28:10 ubuntu-mate kernel: [ 5.862484] usb 1-1.4: new full-speed USB device number 3 using ehci-pci
Dec 13 10:28:10 ubuntu-mate kernel: [ 5.878498] usb 2-1.1: new high-speed USB device number 3 using ehci-pci
Dec 13 10:28:10 ubuntu-mate kernel: [ 5.958962] usb 1-1.4: New USB device found, idVendor=0a5c, idProduct=217f
Dec 13 10:28:10 ubuntu-mate kernel: [ 5.958967] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 13 10:28:10 ubuntu-mate kernel: [ 5.958970] usb 1-1.4: Product: Broadcom Bluetooth Device
Dec 13 10:28:10 ubuntu-mate kernel: [ 5.958978] usb 1-1.4: Manufacturer: Broadcom Corp
Dec 13 10:28:10 ubuntu-mate kernel: [ 5.958979] usb 1-1.4: SerialNumber: xxxxxxxxxxxxx
Dec 13 10:28:10 ubuntu-mate kernel: [ 80.377992] Bluetooth: Core ver 2.21
Dec 13 10:28:10 ubuntu-mate kernel: [ 80.378014] NET: Registered protocol family 31
Dec 13 10:28:10 ubuntu-mate kernel: [ 80.378016] Bluetooth: HCI device and connection manager initialized
Dec 13 10:28:10 ubuntu-mate kernel: [ 80.378021] Bluetooth: HCI socket layer initialized
Dec 13 10:28:10 ubuntu-mate kernel: [ 80.378024] Bluetooth: L2CAP socket layer initialized
Dec 13 10:28:10 ubuntu-mate kernel: [ 80.378031] Bluetooth: SCO socket layer initialized
Dec 13 10:28:10 ubuntu-mate kernel: [ 83.710817] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked
Dec 13 10:28:14 ubuntu-mate bluetoothd[3946]: Bluetooth management interface 1.10 initialized
Dec 13 10:28:14 ubuntu-mate bluetoothd[3946]: Failed to obtain handles for “Service Changed” characteristic
Dec 13 10:28:14 ubuntu-mate kernel: [ 105.016105] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Dec 13 10:28:14 ubuntu-mate kernel: [ 105.016108] Bluetooth: BNEP filters: protocol multicast
Dec 13 10:28:14 ubuntu-mate kernel: [ 105.016113] Bluetooth: BNEP socket layer initialized
Dec 13 10:28:14 ubuntu-mate bluetoothd[3946]: Not enough free handles to register service
Dec 13 10:28:14 ubuntu-mate bluetoothd[3946]: Error adding Link Loss service
Dec 13 10:28:14 ubuntu-mate bluetoothd[3946]: message repeated 2 times: [ Not enough free handles to register service]
Dec 13 10:28:14 ubuntu-mate bluetoothd[3946]: Current Time Service could not be registered
Dec 13 10:28:14 ubuntu-mate bluetoothd[3946]: gatt-time-server: Input/output error (5)
Dec 13 10:28:14 ubuntu-mate bluetoothd[3946]: Sap driver initialization failed.
Dec 13 10:28:14 ubuntu-mate bluetoothd[3946]: sap-server: Operation not permitted (1)
Dec 13 10:28:32 ubuntu-mate NetworkManager[3908]: [1481624912.6405] Loaded device plugin: NMBluezManager (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-bluetooth.so)
Dec 13 10:29:12 ubuntu-mate bluetoothd[3946]: Endpoint registered: sender=:1.26 path=/MediaEndpoint/A2DPSource
Dec 13 10:29:12 ubuntu-mate bluetoothd[3946]: Endpoint registered: sender=:1.26 path=/MediaEndpoint/A2DPSink
Dec 13 10:29:13 ubuntu-mate kernel: [ 163.823210] Bluetooth: RFCOMM TTY layer initialized
Dec 13 10:29:13 ubuntu-mate kernel: [ 163.823219] Bluetooth: RFCOMM socket layer initialized
Dec 13 10:29:13 ubuntu-mate kernel: [ 163.823225] Bluetooth: RFCOMM ver 1.11
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/lib/modules/4.4.0-31-generic/kernel/net/bluetooth/bluetooth.ko: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/lib/modules/4.4.0-31-generic/kernel/drivers/bluetooth/btbcm.ko: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/etc/dbus-1/system.d/bluetooth.conf: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/lib/modules/4.4.0-31-generic/kernel/drivers/bluetooth/btrtl.ko: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/lib/modules/4.4.0-31-generic/kernel/drivers/bluetooth/btusb.ko: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/usr/lib/bluetooth/bluetoothd: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/lib/systemd/system/bluetooth.target: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/etc/bluetooth/main.conf: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/etc/bluetooth/proximity.conf: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/etc/bluetooth/input.conf: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/etc/bluetooth/network.conf: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/lib/modules/4.4.0-31-generic/kernel/net/bluetooth/bnep/bnep.ko: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-bluetooth.so: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/lib/udev/rules.d/50-bluetooth-hci-auto-poweron.rules: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/usr/lib/pulse-8.0/modules/module-bluetooth-policy.so: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/usr/lib/pulse-8.0/modules/module-bluetooth-discover.so: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/lib/modules/4.4.0-31-generic/kernel/net/bluetooth/rfcomm/rfcomm.ko: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:K01bluetooth: Ignored relative path
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:S03bluetooth: Ignored relative path
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:bluetooth: Ignored relative path
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/lib/systemd/system/bluetooth.service: Error retrieving chunk extents: Operation not supported
Dec 13 10:31:17 ubuntu-mate ureadahead[2350]: ureadahead:/usr/lib/bluetooth/obexd: Error retrieving chunk extents: Operation not supported
No doubt there is something wrong. I cannot make out the root cause, however, but it seems to have been introduced by 16.04.1. Can someone in the know take a look at this, please?
Cheers
GUJ
