This is annoying for something as basic as bluetooth, I can sync to my car easier then my PC.
I’m running 16.04
So I’m trying to connect my Galaxy S6 to my PC via Bluetooth, the PC can see the phone and goes through the pairing but then it crashes and I get this
Bluez daemon is not running, blueman-manager cannot continue. This probably means that there were no Bluetooth adapters detected or Bluetooth daemon was not started.
Had a search and it seems there’s a lot of way to fix this, tried a couple with no luck.
Any help would be grand.
could be the adapter is busted I guess.
thanks.
Mark.
