Since installing Ubuntu MATE 17.04 LibreOffice icons are very blurry.
Is it only on my machine?
Using Intels onboard graphics (i5 6500 CPU)
have you tried to reset in libreoffice writer?
It’s a new install. But how can i reset LibreOffice?
you can try some of the other icon sets for libreoffice and see if they are blurry or not? for more info: https://www.howtogeek.com/285752/how-to-change-the-size-and-style-of-the-icons-in-libreoffice/
Yes, i did. I tried also the Office2013 icon set from charliecnr. But the problem still exists. All the sets are working fine for LO 5.3 on Ubuntu MATE 16.10.
Have you tried installing a new icon theme for LibreOffice from the repository?
From the terminal you can search for one by issuing
apt search libreoffice-style
which should return something similar to
Sorting... Done
Full Text Search... Done
libgtkspellmm-3.0-0v5/zesty 3.0.5+dfsg-1 amd64
C++ wrapper library for GtkSpell (shared libraries)
libgtkspellmm-3.0-dev/zesty 3.0.5+dfsg-1 amd64
C++ wrapper library for GtkSpell (development files)
libgtkspellmm-3.0-doc/zesty,zesty 3.0.5+dfsg-1 all
C++ wrappers for GtkSpell (documentation)
libreoffice-style-breeze/zesty,zesty 1:5.3.1-0ubuntu2 all
office productivity suite -- Breeze symbol style
libreoffice-style-elementary/zesty,zesty,now 1:5.3.1-0ubuntu2 all [installed]
office productivity suite -- Elementary symbol style
libreoffice-style-galaxy/zesty,zesty,now 1:5.3.1-0ubuntu2 all [installed]
office productivity suite -- Galaxy (Default) symbol style
libreoffice-style-hicontrast/zesty,zesty 1:5.3.1-0ubuntu2 all
office productivity suite -- Hicontrast symbol style
libreoffice-style-human/zesty,zesty 1:5.3.1-0ubuntu2 all
transitional package for Human symbol style
libreoffice-style-oxygen/zesty,zesty 1:5.3.1-0ubuntu2 all
office productivity suite -- Oxygen symbol style
libreoffice-style-sifr/zesty,zesty 1:5.3.1-0ubuntu2 all
office productivity suite -- Sifr symbol style
libreoffice-style-tango/zesty,zesty,now 1:5.3.1-0ubuntu2 all [installed]
office productivity suite -- Tango symbol style
From there install a style of your choice. For example:
sudo apt install libreoffice-style-oxygen
Restart LibreOffice and navigate to Tools > Options > View and change the icon style from the drop down menu.
Note: The icon styles are installed at /usr/share/libreoffice/share/config
Also, have you tried adjusting the Toolbar icon size in Tools > Options > View ?
Thank you, but i am gone back to Ubuntu MATE 16.10. So this problem is solved for me.
There were to many problems on my system:
I love Ubuntu MATE, but at the moment 17.04 isnt ready for me.
