Bomi opens folders instead of Caja
I’m on Ubuntu MATE 15.04 x64 and installed bomi as my media player. Whenever I open a folder location from the system tray (Redmont), e.g. Show Folder from the Dropbox or Insync menus it opens them in bomi instead.
Seeing that bomi development is on hiatus I was hoping that it may be a MATE issue which could be fixed.
I’m not sure what to look for. bomi is registered as the default player for video but nothing else.
Cheers,
Tim
Pretty sure this should be fix in 15.10.
Thanks, @Wimpy
What if I can’t upgrade to 15.10 yet for compatibility reasons? Is there something I can install or change that fixes this?
