I want to order my first Raspberry Pi 3 with an extension USB to compact flash board converter.
https://www.voelkner.de/products/897236/pri-x225.jpg
Because I have an SunDisk 32 GB CF Extreme Pro 90 MB/s, UDMA 6 hanging around here,
because I want avoid to buy an mSATA SSD Drive.
My question is:
- Is it possible to boot the Linux system direct from the Compact Flash, without SD-Card?
- It is faster then a SD-Card over USB?
Regards to all…
