I’m trying to install Ubuntu 15.10 Mate onto a USB drive that will boot with Ubuntu running as the operating system (in a persistent way, not as a live
demo). That way i can keep my work files on both my main computer’s HDD and on the USB drive…and just take the USB with me when i need to work out of town.
First, I formatted the USB by doing the following…
I got the usb dev name:
sudo fdisk -l
I unmounted the usb:
sudo umount /dev/sd@
I formatted usb as FAT32:
mkdosfs -F 32 -I /dev/sd@
Then i used UNetbootin
to create a startup USB using the Ubuntu 15.10 Mate .iso file on my main computer (HDD).
After UNetbootin ran it said that all was done correctly and that i just needed to reboot the system. I have my system set up so that it first tries to boot from the USB drive…but when i rebooted the only options that i had were to run ‘Live’ Ubuntu from the USB drive OR to install Ubuntu from the USB drive to my main computer (HDD).
Currently my USB drive looks like this…
Disk /dev/sdb: 111.8 GiB, 120034123776 bytes, 234441648 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 33553920 bytes
Disklabel type: dos
Disk identifier: 0x20ac7dda
Device Boot Start End Sectors Size Id Type
/dev/sdb1 3224498923 3657370039 432871117 206.4G 7 HPFS/NTFS/exFAT
/dev/sdb2 3272020941 5225480974 1953460034 931.5G 16 Hidden FAT16
/dev/sdb3 0 0 0 0B 6f unknown
/dev/sdb4 50200576 974536369 924335794 440.8G 0 Empty
Prior to using UNetbootin i tried to install the operating system via the dd command like this…
sudo dd if=/mypath/myisofile.iso of=/dev/sdb
…with the same results.
What am i doing wrong?
