I started seeing 2 T-Birds and 2 Firefoxs On my bottom panel the other day. Image sent in message.
I believe 1 each is fine. The others are taking up to much room down there.
How do I remove the 1 set without causing problems to the panel?
I don't remember what happened just before these extra 2 appeared.
I'm old , not near a geek. Please state what to do in layman's terms.
Thank You
mt
tkn
2
Hi MateTwo,
The window-list-panel-applet is the one that displays your T-bird and Firefox buttons.
You ended up with two instances of the window-list-panel-applet on your panel.
You want one of them deleted.
Right-click just left of that T-bird button, you will get a small menu:
Choose the "remove from panel" option.
(If the option is greyed out and there is a 'tick' next to "lock to panel", untick that first.)
Thank You! tkn Something worked that was easy.....................
mt
