I am using the latest MATE on a IBM T60. When I try to write a cd it writes so far then fails. The writer is fine in other distros and it does write DVD’s correctly on MATE but just won’t write CDs. I tried xfburn but that too fails. Any suggestions please.
Thank you.
Hello are you getting some sort of error message?
Are you trying to burn the disks at maximum speed?, this might cause a fail?, try burning disks at the slowest possible speed!. ![]()
If all else fails, use k3b burning app. To install via a terminal with the following command (Ctrl + Alt + t):
sudo apt-get install k3b
The error is just burn process failed. Sometimes this is almost instant as soon as the operation starts or sometimes after a minute or so. It does put something on the discs as they are no longer blank and its ruined a stack of blanks.
I did try slowing the burn speed but still the same. If I do a dummy write then I get success but the actual write still fails. I have installed Mint and will try some writes in that to make really be sure the drive itself isn’t faulty and report back.
Clean the DVD drive with a disk cleaner!
k3b is perfect, but some additional stuff is installed as well (dependencies).
i used to have problems with brasero, but now i first burn an image file and then burn it to a cd disc. in this case i usually face no problems
Sometimes when I’m burning a ISO file to a disk a simple thing like cleaning the disk will works wonders. I’ve since only use USB thumb drives to create my installations less trouble
It is almost certain that there is a problem with the drive and this is not a fault in the OS. So sorry guys and thanks for your replies.
Did you follow the advice above?. ![]()
