Hello, I have quite some time using Ubuntu Mate, Recently I got a Dell Inspiron 3493 with a Intel UHD 620 intagrated graphics and a Core i3 Intel Processor 1001-G1, I'm currently facing a problem, when I'm using my laptop for regular basis suddenly it looks like the brightness reset itself, seems like suddenly goes brighter to a 100% and then goes back to the normal percentage I usually use it a 15% of brightness similar when you take an screenshot, honestly I tried ignoring the issue and it is annoying. I already disable the PSR option from the kernel and remove the intel graphics for x11, also disable the automatic brightness option using dconf-editor and still, keeps happening every 25 to 30 minutes, I would like to request help and if you need me to attach something please ping me I'll be checking this thread.
Thanks in advance
