Hello.
I have a fresh installation of Mate 23.04. I use two monitors. I added a new panel on the first monitor, reduced it, moved to the second monitor and expanded it at the bottom.
I added a brisk menu on this second panel.
The problem: at each reboot, the brisk menu on the FIRST panel (the original one) is empty.
I can use the update-menus to recreate it, but its prompt confirmation every time.
Is there another way to fix the bug?
