When using the Brisk Menu to logout/shutdown/reboot it is always necessary for me to do this twice. The first try never takes, the second try will perform the task.
Anyone else seeing this?
It’s been working normally for me. Clocking the button in Brisk opens the dialog, and then that shuts it off or reboots.
Thanks elcste
That doesn’t surprise me, my primary install has been kicked around and I have a few self inflicted bugs. I’ll be reinstalling in a couple of weeks and this will probably go away. Just wanted to verify its not a bug.
