Brltty package crash shortly after every bootup
After upgrading to 16.10 I get a package crash within 30 seconds of loading the desktop every time the computer boots. The package is brltty which appears to be related to braille device support. This isn’t a package I use or need, just appears to be part of the MATE desktop or the ubuntu base.
Oct 31 11:51:44 ubuntu brltty[360]: brltty: BrlAPI connection fd=1019 accepted: inet 127.0.0.1:46168
Oct 31 11:51:46 ubuntu brltty[360]: BrlAPI connection fd=1020 accepted: inet 127.0.0.1:46170
Oct 31 11:51:46 ubuntu brltty[360]: brltty: BrlAPI connection fd=1020 accepted: inet 127.0.0.1:46170
Oct 31 11:51:51 ubuntu brltty[360]: BrlAPI connection fd=1021 accepted: inet 127.0.0.1:46172
Oct 31 11:51:51 ubuntu brltty[360]: brltty: BrlAPI connection fd=1021 accepted: inet 127.0.0.1:46172
Oct 31 11:51:52 ubuntu brltty[360]: *** %n in writable segment detected ***
Oct 31 11:51:53 ubuntu acpid: input device has been disconnected, fd 23
Oct 31 11:51:53 ubuntu systemd[1]: brltty.service: Main process exited, code=dumped, status=6/ABRT
Oct 31 11:51:53 ubuntu systemd[1]: brltty.service: Unit entered failed state.
Oct 31 11:51:53 ubuntu systemd[1]: brltty.service: Failed with result ‘core-dump’.
Oct 31 11:52:23 ubuntu systemd[1]: brltty.service: Service hold-off time over, scheduling restart.
Syslog is just full of the API reconnecting all the time
Oct 31 12:19:00 ubuntu brltty[2997]: BrlAPI connection fd=37 accepted: local
Oct 31 12:19:00 ubuntu brltty[2997]: brltty: BrlAPI connection fd=37 accepted: local
Oct 31 12:19:01 ubuntu brltty[2997]: BrlAPI connection fd=37 accepted: local
Oct 31 12:19:01 ubuntu brltty[2997]: brltty: BrlAPI connection fd=37 accepted: local
I too am having problems with the brltty service. I’ve tried “sudo systemctl disable brltty.service” as I don’t need braille support, and I end up with the following:
Executing /lib/systemd/systemd-sysv-install disable brltty
insserv: warning: current start runlevel(s) (empty) of script brltty' overrides LSB defaults (S). insserv: warning: current stop runlevel(s) (S) of scriptbrltty’ overrides LSB defaults (empty).
