wireless_difficulties_18.04 alpha - February 24, 2018
My broadcom wireless worked on UM 18.04 alpha until an update on Thursday, Feb. 22nd and perhaps a little before. Following are the terminal commands I ran to get some sort of hint on each kernel.
4.13.0-32-generic - working
[email protected]:~$ iwconfig
wlan0 IEEE 802.11 ESSID:“imelda”
Mode:Managed Frequency:2.412 GHz Access Point: 00:13:10:8F:16:CA
Bit Rate=9 Mb/s Tx-Power=20 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:off
Link Quality=70/70 Signal level=-37 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:1 Invalid misc:57 Missed beacon:0
enp9s0 no wireless extensions.
lo no wireless extensions.
4.15.0-10-generic - non working
[email protected]:~$ ifconfig
enp9s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 00:1c:23:93:26:45 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 17
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 136 bytes 9759 (9.7 KB)
TX packets 136 bytes 9759 (9.7 KB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.153 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::a2c9:63a7:46d3:d3a4 prefixlen 64 scopeid 0x20
ether 00:1c:26:3e:b1:89 txqueuelen 1000 (Ethernet)
RX packets 100 bytes 25832 (25.8 KB)
RX errors 0 dropped 3 overruns 0 frame 0
TX packets 106 bytes 13827 (13.8 KB)
device interrupt 17
RX packets 304 bytes 19514 (19.5 KB)
TX packets 304 bytes 19514 (19.5 KB)
[email protected]:~$ inxi -N
Network: Card-1: Broadcom Limited NetXtreme BCM5755M Gigabit Ethernet PCI Express driver: tg3
Card-2: Broadcom Limited BCM4311 802.11a/b/g driver: b43-pci-bridge
[email protected]:~$ lspci -vvnn | grep 14e4
09:00.0 Ethernet controller [0200]: Broadcom Limited NetXtreme BCM5755M Gigabit Ethernet PCI Express [14e4:1673] (rev 02)
0c:00.0 Network controller [0280]: Broadcom Limited BCM4311 802.11a/b/g [14e4:4312] (rev 01)
firmware-b43-installer and b43-fwcutter are installed. bcmwl-kernel-source is removed as is dkms.
https://askubuntu.com/questions/55868/installing-broadcom-wireless-drivers a great thread about my favorite wireless card.
So it looks like my wireless driver (b43-pci-bridge) is missing from the latest kernel. How’d that happen?
