Why the kernel is not updated to fix the bug Dirty Cow (CVE-2016-5195)
http://people.canonical.com/~ubuntu-security/cve/2016/CVE-2016-5195.html
It is updated already.
Kernel 4.4.0-45 fixes the issue, as per the changelog (line 3-4):
http://changelogs.ubuntu.com/changelogs/pool/main/l/linux/linux_4.4.0-45.66/changelog
Check if you’re using the fixed kernel using the following command:
ov@Edge:~/Desktop$ cat /proc/cmdline
BOOT_IMAGE=/boot/vmlinuz-4.4.0-45-generic root=UUID=ba221910-241b-4d76-abe4-b2259cba54be ro
Edit:
Alternatively, go to MATE system monitor, in the “system” tab.
Thanks. He had understood that was solved with the Kernel 4.4.0-66. I have it updated.
