Build customized mate-themes from package source
I went on a journey with this post. :slight_smile:
We rise by leveraging the work of others, so ...
Here is my "edit" of the two command sequences that @vkareh provided during that journey.
Why did I do this?
The reason why I pursued this journey is because I wanted to define a reproducible, disciplined workflow, incorporating lessons learned about package customization, build & deployment, as a testbed before attempting more challenging customizations on packages of a critical nature, such as synaptic, etc.
Hope it serves others as well (possibly @guyr) .
(P.S. I am not a fan of the process of creating Makefiles, although I have no qualms using someone else's quality work. :slight_smile: )
(Another bit of cleanup of the script. It is now fully proven.[basic version])
#!/bin/bash
###	Script to perform sequence necessary to have system apply
###	various customization changes to the installed OS
###	Version: 3.0
###	REF:
###	https://ubuntu-mate.community/t/window-adjust-grab-zone-size-issues/28070/14
###	https://ubuntu-mate.community/t/window-adjust-grab-zone-size-issues/28070/16
#23456789+123456789+123456789+123456789+123456789+123456789+123456789+123456789+123456789+123456789+
sep()
	printf "\n\n====================================================================================================\n\n\n"
host="Oasis"
version="3.22.26"
while [ $# -gt 0 ]
do
	testor=$(echo "${2}" | grep "\-\-" )
	case "${1}" in
			if [ -n "${testor}" -o -z "${2}" ]
			then
				printf "\t ERROR: You must specify a version number for the package bundle to proceed.\n" ; exit 1
			fi
			case "${1}" in
				"--host" )
					host="${2}" ; shift ; shift
				"--version" )
					version="${2}" ; shift ; shift
					printf "\t ERROR: Invalid parameter used on the command line.\n" ; exit 1
			esac
	esac
done
label="mate-themes-${version}"
buildDir_themes="${label}/"
packageBundle="${label}.tar.xz"
test "$(pwd | grep "/usr/share/themes" )" = "" ||  { printf "\t ERROR: This script should NOT be run within the OS installation libraries.  Start from within a 'development' workspace.\n" ; exit 1 ; }
if [ -f ${host}.bundle.DONE ]
then
	printf "\t [1] Downloading of '${packageBundle}' previously done ...\n"
else
	wget https://github.com/mate-desktop/mate-themes/releases/download/v${version}/${packageBundle}
	test $? -eq 0  || { printf "\t ERROR: Download of package file '${packageBundle}' failed.\n" ; exit 1 ; }
	test -s "${packageBundle}" || { printf "\t ERROR: Expected package file '${packageBundle}' was not downloaded.\n" ; exit 1 ; }
	touch ${host}.bundle.DONE
	sep
fi
if [ -f ${host}.unbundle.DONE ]
then
	printf "\t [2] Extract of files from '${packageBundle}' previously done ...\n"
else
	tar xvf ${packageBundle}
	test $? -eq 0  || { printf "\t ERROR: Failed to extract files from package file '${packageBundle}'.\n" ; exit 1 ; }
	touch ${host}.unbundle.DONE
	sep
fi
if [ -f ${host}.dependencies.DONE ]
then
	printf "\t [3] Downloading packages '${packageBundle}' requires previously done ...\n"
else
	sudo apt-get build-dep mate-themes
	test $? -eq 0  || { printf "\t ERROR: Failed to retrieve build dependencies for 'mate-themes' package.\n" ; exit 1 ; }
	touch ${host}.dependencies.DONE
	sep
fi
printf "\n\t Proceed with rebuild of MATE Themes ? [y/N] => " ; read ans
if [ -z "${ans}" ]
then
	ans="N"
fi
case "${ans}" in
	y* | Y* ) ;;
	* ) printf "\n\t Rebuild abandoned.\n Bye!\n" ; exit 0 ;;
esac
###	This is where the script would normally re-start on subsequent iterations
###	AFTER you have made the changes you wish to make in the 'source code tree'
cd "${buildDir_themes}"
test $? -eq 0  || { printf "\t ERROR: Failed to to set root of code tree, '${buildDir_themes}', as working directory.\n" ; exit 1 ; }
printf "\t [4] Performing 'autogen.sh' ...\n"
./autogen.sh --prefix=/usr
sep
printf "\t [5] Build stage 1 'make' ...\n"
make
sep
printf "\t [6] Build stage 2 'make install' ...\n"
sudo make install
printf "\n	DONE -- Time to verify the deployment performs as expected.\n\n"
Script updated to version 4.1 on 2024-08-19 17:42 EDT.
Here's a much more complex version of that script but ...
FAIR WARNING, you need to fully understand its logic (flow, conditionals, limitations) to ensure you have no surprises before committing to it !!!
Guide to logic flow:
Outline of Program Logic ― rebuildThemes.sh
<< Script Header >>
do_RefMirror()
Create a mirror duplicate of the initial package code tree after first download, using rsync. This is used for comparison to identify all changes applied to code under the “work” tree.
do_ReportDifferences()
Use rsync “dry run” option to generate list of items that would require extraction and collection as a tar bundle for later submission as a package feature request or for submitting a bug fix.  Generates both,
- a list of files to create the delta “snapshot” tar bundle, and
- a report by rsync of the flags indicative of the nature of the changes.
do_CreatePatchFiles()
Populate the code tree with patch files applicable for modified text files.
do_BuildSnapshotTar()
Create the “snapshot” tar bundle, to keep as refefence of a given internally-consistent set of files for a working configuration.
myLs()
Create customized version of ‘ls l’ to report on files during the progress of the script.  Key aspect is that, if the modification is older than 24 hours, it reports only the date; otherwise it reports only the time of the last change using the 24-hour clock.
sep()
This is just a function to improve visual separation of the reporting, in the terminal, from the various logical segments of the script.
parmError()
This is a function to standardize the error reporting when a command-line parameter is missing.
<< Code Segment 1 ― Initializing parameters and command line parsing >>
<< Code Segment 2 ― Logic and reporting triggered, based on version of code: specified default, detected extracted version or command-line specified.  Handling for an “upgrade” in version is not currently implemented, leaving that to manual intervention by the user himself. >>
<< Code Segment 3 ― Setup of commen referential parameters depending on version number and package name. >>
<< Code Segment 4 ― Logic prompting for code refresh (currently non-functional) and logic prompting for rebuild of “snapshot tar” containing customization changes, namely “${host}.0_reclaimCustom.tar”. >>
<< Code Segment 5 ― Logic for conditional download of the specified package for the specified version.  Create flag file “${host}.1_bundle.DONE” if process completed to indicate bypass at subsequent re-running of script. >>
<< Code Segment 6 ― Logic for conditional extraction of the specified package for the specified version into the required work tree.  Create flag file “${host}.2_unbundle.DONE” if process completed to indicate bypass at subsequent re-running of script. >>
<< Code Segment 7 ― Logic for conditional download and installation of build dependencies to ensure success of build process for specified package at the specified version.  Create flag file “${host}.3_dependencies.DONE” if process completed to indicate bypass at subsequent re-running of script. >>
<< Code Segment 8 ― Logic requesting confirmation to proceed with re-attempt of package build and install. >>
<< Code Segment 9 ― Perform “autogen” action. >>
<< Code Segment 10 ― Perform “build” action. >>
<< Code Segment 11 ― Perform “install” action. >>
<< Code Segment 12 ― Logic for conditional creation of code tree mirror to be used during later comparison for identification of changes that have been applied.  Create flag file “${host}.6_mirror.DONE” if process completed to indicate bypass at subsequent re-running of script. >>
<< Code Segment 13 ― Inactive code segments, retained for possible consideration for later additions to code logic. >>
Log of terminal session
  • after changes have been made in working code tree, build sequence applied and verified good, and updating previous snapshot bundle (of changes).
$ rebuildThemes.sh
	 Version for newest code tree currently on disk is:  3.22.26
	 NOTE:  Version specified is same as most recently worked version ...
	 Re-do attempt using same code version base as previously worked ...
	 Refresh (overwrite) previously downloaded code bundle file ? [y|N] =>
	 Continuing with previously downloaded code bundle file 'mate-themes-3.22.26.tar.xz' ...
	 Detected previously-created customization snapshot bundle 'Oasis.0_reclaimCustom.tar':
	   -rw-rw-r--  1          296960   17:34:04   Oasis.0_reclaimCustom.tar
	 Replace that with newer snapshot ? [y|N] => y
	 These patch files will be added to the snapshot tar file:
	   -rw-rw-r--  1            1272   17:36:07   desktop-themes/BlackMATE-border/metacity-1/metacity-theme-3.xml.patch
	 Will create tar file containing the following files:
	  | desktop-themes/BlackMATE-border/metacity-1/bar_unfocused.DISTRO.png
	  | desktop-themes/BlackMATE-border/metacity-1/bar_unfocused.Oasis.png
	  | desktop-themes/BlackMATE-border/metacity-1/bar_unfocused.png
	  | desktop-themes/BlackMATE-border/metacity-1/metacity-theme-3.DISTRO.xml
	  | desktop-themes/BlackMATE-border/metacity-1/metacity-theme-3.Oasis.xml
	 No errors reported during tar file creation ...
	 Successfully created tar file containing only modified files:
	   -rw-rw-r--  1          296960   17:36:07   Oasis.0_reclaimCustom.tar
	 List of files impacted by all impacting changes:
	   -rw-rw-r--  1             471   17:36:07   Oasis.0_reclaimCustom.tar.list
	 Report [rsync] flagging attributes triggering inclusion in tar file:
	   -rw-rw-r--  1             473   17:36:07   Oasis.0_reclaimCustom.tar.details
	 [1] Downloading of 'mate-themes-3.22.26.tar.xz' ...			previously done ...
	 [2] Extract of files from 'mate-themes-3.22.26.tar.xz' ...		previously done ...
	 [3] Installation of build dependencies for 'mate-themes' package ...	previously done ...
	 Rebuild deferred as directed.
 Bye!
Script:
#!/bin/bash
###	Version: 4.0 (major change, some inactive code segments)
###	Version: 4.1 (added logic to generate patch files and include those in snapshot tar)
###	REF:
do_RefMirror()
	#${doUpdate} \
	#${doCheckSum} \
	#${showProgress} \
	#--verbose --out-format=\"%t|%i|%M|%b|%f|\" \
	COM="ionice -c 2 -n 7 rsync \
	--one-file-system \
	--recursive \
	--outbuf=Line \
	--links \
	--perms \
	--times \
	--group \
	--owner \
	--devices \
	--specials \
	--verbose --out-format=%f \
	--delete-during \
	--whole-file \
	--human-readable \
	--protect-args \
	--ignore-errors \
	--msgs2stderr \
	./ ${PathMirror}/"
	${COM}
	###	REF:
	###	https://superuser.com/questions/1624000/using-rsync-to-quickly-show-only-files-that-have-different-content
	#	-HPrl \
		--hard-links \
		--partial \
		--progress \
		--links \
		--recursive \
		--itemize-changes \
		--dry-run \
		./ ${PathMirror}/"
	#	./ ${START}/${buildDir_themes}"		###  Used for a reversed comparison
	${COM}	| grep -vF "f..T......"  | grep -vF "d..T......"  | grep '^>' | grep "${focus_string}" | grep -v '.patch | tee ../${host}.0_reclaimCustom.tar.details | cut -f2- -d" "
	#       ; no timediff on files   ; no timediff on dirs
	rm -f ${host}.0_reclaimCustom.patchfiles
	while read file
	do
		if [ -f "${buildDir_REF}/${file}" ]
		then
			testor=$( file "${buildDir_REF}/${file}" | cut -f2- -d\: | grep 'ASCII [Tt][Ee][Xx][Tt]' )
			if [ -n "${testor}" ]
			then
				#echo "$testor}" >&2
				#echo diff -Naru "${buildDir_REF}/${file}" "${buildDir_themes}${file}"
				diff -Naru "${buildDir_REF}/${file}" "${buildDir_themes}${file}" >"${buildDir_themes}${file}.patch"
				#echo "${file}.patch" >&2
				echo "${file}.patch" >>${host}.0_reclaimCustom.patchfiles
			fi
		fi
	done <${host}.0_reclaimCustom.list
	if [ -s "${host}.0_reclaimCustom.patchfiles" ]
	then
		printf "\n\t These patch files will be added to the snapshot tar file:\n"
		while read patch
		do
			test -n "${buildDir_themes}${patch}" && {
			( cd "${buildDir_themes}" ;
				myLs "${patch}" 2>&1 | awk '{ printf("\t   %s\n", $0 ) ; }'
			testor=$( grep "${patch}" ${host}.0_reclaimCustom.list )
			test -z "${testor}" && { echo "${patch}" >>${host}.0_reclaimCustom.list ; }
		done <${host}.0_reclaimCustom.patchfiles
	fi
	rm -f ${host}.0_reclaimCustom.list
	( cd "${buildDir_themes}" ; do_ReportDifferences >../${host}.0_reclaimCustom.list 2>../${host}.0_reclaimCustom.err )
	if [ -s ${host}.0_reclaimCustom.list ]
	then
		do_CreatePatchFiles
		printf "\n\t Will create tar file containing the following files:\n"
		awk '{ printf("\t  | %s\n", $0 ) ; }' ${host}.0_reclaimCustom.list
		( cd "${buildDir_themes}" ; tar cvf ../${host}.0_reclaimCustom.tar -T ../${host}.0_reclaimCustom.list ) >${host}.0_reclaimCustom.tar.list 2>${host}.0_reclaimCustom.tar.err
		test -s ${host}.0_reclaimCustom.tar.err && {
			printf "\n\t Errors reported during tar file creation:\n"
			awk '{ printf("\t  | %s\n", $0 ) ; }' <"${host}.0_reclaimCustom.tar.err"
			printf "\n\t No errors reported during tar file creation ...\n" ;
			rm -f ${host}.0_reclaimCustom.tar.err
		test -s ${host}.0_reclaimCustom.tar && {
			printf "\n\t Successfully created tar file containing only modified files:\n" ;
			myLs "${host}.0_reclaimCustom.tar" 2>&1 | awk '{ printf("\t   %s\n", $0 ) ; }'
			printf "\n\t Empty file:  '${host}.0_reclaimCustom.tar' \n" ;
			rm -fv ${host}.0_reclaimCustom.tar 2>&1 | awk '{ printf("\t\t %s\n", $0 ) ; }' ;
			exit 1 ;
		test -s ${host}.0_reclaimCustom.tar.list && {
			printf "\n\t List of files impacted by all impacting changes:\n" ;
			myLs "${host}.0_reclaimCustom.tar.list" 2>&1 | awk '{ printf("\t   %s\n", $0 ) ; }'
			printf "\n\t Empty file:  '${host}.0_reclaimCustom.tar.list' \n" ;
			rm -fv ${host}.0_reclaimCustom.tar.list 2>&1 | awk '{ printf("\t\t %s\n", $0 ) ; }' ;
		test -s ${host}.0_reclaimCustom.tar.details && {
			printf "\n\t Report [rsync] flagging attributes triggering inclusion in tar file:\n" ;
			myLs "${host}.0_reclaimCustom.tar.details" 2>&1 | awk '{ printf("\t   %s\n", $0 ) ; }'
			printf "\n\t Empty file:  '${host}.0_reclaimCustom.tar.details' \n" ;
			rm -fv ${host}.0_reclaimCustom.tar.details 2>&1 | awk '{ printf("\t\t %s\n", $0 ) ; }' ;
		echo ""
	else
		if [ ${force} -eq 0 ]
		then
			printf "\n\t WARNING:  No differences detected between 'Work Code tree' and 'Reference Code tree'.\n\t\t   Visual inspection is STRONGLY RECOMMENDED before adding the '--force' option to proceed beyond this step.\n" ; exit 1
		fi
	fi
myLs()
	#eval stat --format=\"\|\%A\|\%h\|\%s\|\%y\|\%n\|\" \"${1}\"
	eval stat --format=\"\|\%A\|\%h\|\%s\|\%Y\|\%n\|\" \"${1}\" |
	awk -v now=${time_now} '{
		n=split( $0, vals, "|" ) ;
		#mult24=( (1.0*now) - vals[5] )/86400 ;
		#print mult24 ;
		# 86400 seconds in a 24 hour period
		if( ( (1.0*now) - vals[5] )/86400 > 1 ){
			printf("%s %2s %15s  %10s  %s\n", vals[2], vals[3], vals[4], strftime("%F", vals[5]), vals[6] ) ;
		}else{
			printf("%s %2s %15s  %9s   %s\n", vals[2], vals[3], vals[4], strftime("%R:%S", vals[5]), vals[6] ) ;
sep()
parmError()
	printf "\n\t ERROR: You must specify a ${msg} to proceed.\n" ; exit 1
version_worked=$(ls -d mate-themes-[0-9].[0-9][0-9].[0-9][0-9] | sort -nr | head -1 | awk '{ n=split($0, vars, "-") ; print vars[n] ; }' )
printf "\n\t Version for newest code tree currently on disk is:  ${version_worked}\n\n"
START=$(pwd)
host="Oasis"
packageName="mate-themes"
version="3.22.26"
focus_string="BlackMATE-border"
reclaim=0
snapshot=0
force=0
version_up=0
while [ $# -gt 0 ]
do
	case "${1}" in
		"--snapshot" )
			snapshot=1 ; shift
		"--force" )
			force=1 ; shift
			case "${1}" in
				"--host" )
					msg="single-word host label"
					if [ -n "${testor}" -o -z "${2}" ] ; then  parmError ; fi
				"--package" )
					msg="single-word package name"
					packageName="${2}" ; shift ; shift
				"--version" )
					msg="version number"
					printf "\n\t ERROR: Invalid parameter used on the command line.\n" ; exit 1
			esac
	esac
done
time_now=$(date +%s) 			# echo ${time_now}
if [ "${version}" = "${version_worked}" ]
then
	printf "\t NOTE:  Version specified is same as most recently worked version ...\n"
	printf "\t Re-do attempt using same code version base as previously worked ...\n"
else
	newer=$( { echo "${version}" ; echo "${version_worked}" ; } | sort -nr | head -1 )
	if [ "${newer}" = "${version_worked}" ]
	then
		printf "\t WARNING:  Ignoring specification of older code version ...\n"
	else
		printf "\t VERSION CHANGE:  Newer code version base specified, ${version} vs previous ${version_worked} ...\n"
		version_up=1
		echo "
		###	FUTURES:
		###	LOGIC for this condition needs to be defined.
		###	Until then, must intervene manually to ensure no loss of customization.
		exit
	fi
fi
label="${packageName}-${version}"
buildDir_REF="${label}_REF"
buildDir_DIFF="${label}_DIFF"
PathMirror="${START}/${buildDir_REF}"
#echo "${PathMirror}"
test "$(pwd | grep "/usr/share/themes" )" = "" ||  { printf "\n\t ERROR: This script should NOT be run within the OS installation libraries.  Start from within a 'development' workspace.\n" ; exit 1 ; }
test "$(pwd | grep "${label}" )" = "" ||  { printf "\n\t ERROR: This script should NOT be run within the extracted MATE Themes code branch.\n\t Instead, must start from directory containing the downloaded/extracted code branch, namely, the 'development' workspace.\n" ; exit 1 ; }
if [ -s "${packageBundle}" ]
then
	if [ ${snapshot} -eq 0 ]
	then
		printf "\n\t Refresh (overwrite) previously downloaded code bundle file ? [y|N] => " ; read ans
		if [ -z "${ans}" ]
		then
			ans="N"
		fi
		case "${ans}" in
			y* | Y* )
				snapshot=1
				reclaim=1
				###	FUTURES:  logic for code refresh
				#printf "\t Entering code refresh loop ...\n"
				#oldLogic
				#newLogic
			* )	printf "\t Continuing with previously downloaded code bundle file '${packageBundle}' ...\n"
		esac
	fi
	if [ -s ${host}.0_reclaimCustom.tar ]
	then
		overwrite="N"
		echo ""
		printf "\n\t Detected previously-created customization snapshot bundle '${host}.0_reclaimCustom.tar':\n"
		printf "\n\t Replace that with newer snapshot ? [y|N] => " ; read overwrite
		if [ -z "${overwrite}" ]
		then
			overwrite="N"
		fi
		case "${overwrite}" in
			y* | Y* )
				snapshot=1
			* )	printf "\t CONFIRMED:  Preserving OLD customization snapshot bundle '${host}.0_reclaimCustom.tar' ...\n"
				snapshot=0
		esac
	fi
	if [ ${snapshot} -eq 1 ]
	then
		no_snap=0
		if [ ! -f "${host}.2_unbundle.DONE" ]	; then  no_snap=1 ; printf "\t\t Code tree create process not completed.\n" ; fi
		if [ ! -f "${host}.6_mirror.DONE" ]	; then  no_snap=1 ; printf "\t\t Code mirror tree create process not completed.\n" ; fi
		if [ ! -d "${START}/${buildDir_themes}" ]	; then  no_snap=1 ; printf "\t\t Code tree directory missing.\n" ; fi
		if [ ! -d "${START}/${build_Dir_REF}" ]		; then  no_snap=1 ; printf "\t\t Code mirror tree directory missing.\n" ; fi
		if [ ${no_snap} -eq 1 ]
		then
			printf "\n\t ERROR: Pre-conditions for creating requested snapshot are not met. Abandoning process.\n" ; exit 1
		else
			do_BuildSnapshotTar
		fi
	else
		echo ""
	fi
fi
if [ -f ${host}.1_bundle.DONE ]
then
	printf "\t [1] Downloading of '${packageBundle}' ...\t\t\tpreviously done ...\n"
else
	wget https://github.com/mate-desktop/mate-themes/releases/download/v${version}/${packageBundle} 2>&1
	test $? -eq 0  || { printf "\n\t ERROR: Download of package file '${packageBundle}' failed.\n" >&2 ; exit 1 ; }
	} | tee ${host}.1_bundle.log
	test -s "${packageBundle}" || { printf "\n\t ERROR: Expected package file '${packageBundle}' was not downloaded.\n" ; exit 1 ; }
	touch ${host}.1_bundle.DONE
	sep
fi
if [ -f ${host}.2_unbundle.DONE ]
then
	printf "\t [2] Extract of files from '${packageBundle}' ...\t\tpreviously done ...\n"
else
	tar xvf ${packageBundle} 2>&1
	test $? -eq 0  || { printf "\n\t ERROR: Failed to extract files from package file '${packageBundle}'.\n" >&2 ; exit 1 ; }
	} | tee ${host}.2_unbundle.log
	touch ${host}.2_unbundle.DONE
	sep
fi
if [ -f ${host}.3_dependencies.DONE ]
then
	printf "\t [3] Installation of build dependencies for '${packageName}' package ...\tpreviously done ...\n"
else
	sudo apt-get build-dep ${packageName} 2>&1
	test $? -eq 0  || { printf "\n\t ERROR: Failed to retrieve build dependencies for '${packageName}' package.\n" >&2 ; exit 1 ; }
	} | tee ${host}.3_dependencies.log
	touch ${host}.3_dependencies.DONE
	sep
fi
if [ -z "${ans}" ]
then
	ans="N"
fi
case "${ans}" in
	y* | Y* ) continue ;;
	* ) printf "\n\t Rebuild deferred as directed.\n Bye!\n\n" ; exit 0 ;;
esac
test $? -eq 0  || { printf "\n\t ERROR: Failed to to set root of code tree, '${buildDir_themes}', as working directory.\n" ; exit 1 ; }
./autogen.sh --prefix=/usr | tee ../${host}.4_autogen.log
sep
make | tee ../${host}.5_make.log
sep
sudo make install | tee ../${host}.6_install.log
sep
cd "${START}"
if [ -f ${host}.6_mirror.DONE ]
then
	printf "\t [6b] 'Reference Mirror' of '${packageBundle}' already exists.  No need to create.\n"
else
	rm -f ${host}.6_dirset.FAIL
	test -d "${buildDir_themes}" || { printf "\n\t ERROR: Failed to locate '${buildDir_themes}' to set as work directory for creating comparison mirror.\n" >&2 ; exit 1 ; }
	if [ -d "${PathMirror}" ]
	then
		rm -fv ${host}.6_mirror.log ${host}.6_mirror.err
	else
		mkdir -v "${PathMirror}"
	fi
	test -d "${PathMirror}" || { printf "\n\t ERROR: Was unable to create directory '${PathMirror}' for mirroring code tree for later comparison.\n" >&2 ; exit 1 ; }
		test $? -eq 0 || { touch ${host}.6_dirset.FAIL ; exit 1 ; }
		do_RefMirror >../${host}.6_mirror.log
	) 2>&1 | tee ${host}.6_mirror.err
	test -f ${host}.6_dirset.FAIL && { printf "\n\t ERROR: Failed to set '${buildDir_themes}' as work directory for creating comparison mirror.\n" >&2 ; rm -f ${host}.6_mirror.log ${host}.6_mirror.err ; exit 1 ; }
	printf "\t Code tree from '${buildDir_themes}' has been successfully mirrored under '${PathMirror}' ...\n"
	touch ${host}.6_mirror.DONE
fi
printf "\n	BUILD DONE -- Time to verify the deployment performs as expected.\n\n"
exit
exit
exit
###	NON-FUNCTIONAL Code segments segregated for possible future use
###	to expand script functionality for advancing to newer versions "more intelligently"
oldLogic()
	###	LOGIC currently disabled
	if [ -d "${buildDir_REF}" -a -d "${buildDir_themes}" ]
	then
		if [ ! -f "${host}.2_reclaim.DONE" ]
		then
			do_Reclaim
		fi
		echo "past"
		exit
		if [ -f "${host}.2_reclaim.DONE" ]
		then
			echo "====  " rm -rf "${buildDir_REF}"
			echo "====  " mv -v "${buildDir_themes}" "${buildDir_REF}"
			printf "\n\t NOTE:  Previously downloaded code branch, containing modifications, has been preserved for reclaim of changes ...\n"
		else
			printf "\n\t PROBLEM:  Modified files have not yet been reclaimed from the previously downloaded code branch.\n\t Unable to proceed.\n" ; exit 1
		fi
	fi
newLogic()
	echo "====  " rm -v ${packageBundle}
	echo "====  " rm -fv ${host}.1_bundle.DONE
	echo "====  " rm -fv ${host}.1_bundle.log
	echo "====  " rm -fv ${host}.2_unbundle.DONE
	echo "====  " rm -fv ${host}.2_unbundle.log
	echo "====  " rm -fv ${host}.3_dependencies.DONE
	echo "====  " rm -fv ${host}.3_dependencies.log
do_Reclaim()
	rm -f tmp.new tmp.old tmp.diff
	#( cd "${buildDir_themes}" ; find . -print | sort | cut -c3- ) >tmp.new
	( cd "${buildDir_REF}"   ; find . -print | sort | cut -c3- ) >tmp.old
	if [ -s tmp.old ]
	then
		while read line
		do
			testorT=$(find "$(dirname "${buildDir_REF}/${line}" )" -name "$(basename "${line}" )" -newer "${buildDir_themes}${line}" -print )
			if [ -n "${testorT}" ]
			then
				rm -f tmp.diff
				diff "${buildDir_themes}${line}" "${buildDir_REF}/${line}" >tmp.diff
				if [ -s tmp.diff ]
				then
					printf "${testorT}\n"
					awk '{ printf("\t| %s\n", $0 ) ; }' <tmp.diff
				else
					printf "${testorT}\t\t NO_DIFF\n"
				fi
			#	echo cp -pv "${testor}" "${buildDir_themes}${line}"
			fi
			read <&2
		done <tmp.old
		#touch ${host}.2_reclaim.DONE
	else
		printf "\n\t NOTE:  Both '${buildDir_REF}' and '${buildDir_themes}' contain the same files.\n\t\tCan proceed safely with purging of '${buildDir_REF}' ...\n"
	fi
#"${buildDir_themes}"
#"${buildDir_REF}"
do_Reclaim_OLD()
	diff tmp.new tmp.old | grep '^>' | cut -c3- >tmp.diff
	#cat tmp.diff
	if [ -s tmp.diff ]
	then
		while read line
		do
			cp -pv "${buildDir_REF}/${line}" "${buildDir_themes}${line}"
		done <tmp.diff
	else
	fi
#"${buildDir_REF}"
@ericmarceau Thanks for this post, and for your work with this script. Should come in handy during future upgrades. :+1:
