In Caja pane, right click on any item in directory listing. There is a 'Move To' item in that menu but the only locations on option are Desktop, Home, and "other pane" which is active only where another caja window is open.
Hi BWallard,
Seems you're not alone with this desire. There's a workaround by Mdooley creating specific scripts in contextual menu.
Other option is locate this scripts in caja-actions, thing what I very use alternatively.
Thank you Tim, workaround worked great. Been looking off and on for the solution.
BWallard
Possibly you did not change the permissions on the scripts to allow executing file as a program. I had that problem initially.
Then right click shows Scripts and your scripts should show. Before I changed permissions the Scripts was not there.
