Hello,
When I try to put the computer to sleep, shutdown, etc I get 'A program is still running' and it is showing: 'Caja Copying Files'.
Even after a reboot it is doing it. I have to click on 'suspend anyway' and then a second prompt appears exactly the same and I have to click again a second time 'suspend anyway'
At the forum home page there are only two entries visible to me: help/support and hardware and help/support is only for raspberry pi. So unless I'm looking in the wrong place this forum only seems to support hardware and the pi....
FYI, this is not true. AFAIK, "Hardware" and "Raspberry Pi" are actually just sub-categories under the "Support & Help Requests" category. You can post straight under the "Support & Help Requests" category itself without posting under one of the sub-categories (click the text "Support & Help Requests" instead of the lower text), but it's still generally recommended that you add other tags to your post to categorize your post somewhat specifically.
