Hi!
The "computer" view in caja shows all partitions I have on the laptop, but no details about them whatsoever in list view. See below:
Is this normal?
Thanks for any help.
Nope
Hi!
Is this normal?
Nope
Is there a tool which shows me all the information at one glance which I now need to get together from caja, gparted and disks?
A terminal command would be:
df -T
Your system monitor will show mounted file systems.
A small script could be turned into a launcher to give you quick access to certain information at a click. Depends on what info you want.
Thanks. That one I did not have on my radar anymore.
