Hi there,
I've some trouble to connect a volume via ssh with caja-connect-server dialog.
What I fill in:
- Server: IPv4-Address of local network server
- Port: 22
- Type: ssh
- Folder: /home/ast
- User Name: ast
- Password: **********
- No check on Bookmark
- No Bookmark name
Result is: Connection failed (message at top of dialog box).
What I've checked so far:
SSH is running at desired IP-address
SFTP Subsystem at 'server' is running
Password and user are correct
ssh ast@IP
works like a charm -
on local machine (where I try to connect from) gfvs-backend, gfvs-sshfs and other candidates are installed
UFW/iptables is not blocking anything, in fact, switched it off for testing
looked into logs on server (deamon.log, syslog, auth.log). auth.log recognized a correct connection, which is disconnected 'by user' immediately, no error messages in other mentioned log files.
I ran caja-connect-server from commandline: no messages at all
Local Machine uname: 'Linux kei 5.0.0-27-generic #28-Ubuntu SMP Tue Aug 20 19:53:07 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux' / Ubuntu 19.04, freshly upgraded
Remote Machine uname: 'Linux ncserv 3.16.0-7-amd64 #1 SMP Debian 3.16.59-1 (2018-10-03) x86_64 GNU/Linux' / Debian 8.11 (jessie).
Does anyone has any idea, why I can't connect?
Greetings,
fabos
