Caja image converter - Change Quality settings
Hi there
I’ve been using Caja image converter for quite a while and i really like this tool. It adds a context menu entry to caja when right clicking images
Does anyone know if there is a way to change some settings for this conversion?
The thing I like to change is the quality settings. If i save a file in pinta or some other program I have the option to save it at 85% of quality which makes a huge difference in the file size and no real visual difference. Saving a file in the same resolution with caja-image-converter results in a file which is about 3times the size.
Caja Image Converter is using Imagemagick so I assume it is just a small script passing some values to imagemagick. But where would that script be stored?
