My Caja has become like this. I mean no options of side pane, etc. How to restore it ? I am new to Mate and don't know anything about it. Help please
Hi
You should go to “view” on the top panel of Caja (file manager) - Which LAyout are you using ? ( go to Mate tweak > Panel)
Solved.
Thanks mate
Don’t panic, you are using GNU/Linux
