Caja not starting
I see "Starting xdg-open" in the taskbar if I try doing it from the menu and this from the command line:
user@mate:~$ caja
Could not register the application: GDBus.Error:org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from message bus without replying
user@mate:~$ caja --check
running caja_self_check_file_utilities
running caja_self_check_file_operations
running caja_self_check_directory
running caja_self_check_icon_container
user@mate:~$ caja --no-desktop
user@mate:~$ caja --force-desktop
Ubuntu MATE 20.04, amd64, after a reboot.
Hi @lovingboth,
Was your system restored from a backup ?
(in this case i found this)
Otherwise, can you try to open caja as root and share the result ?
No.
What's worked is logging out and logging back in again. I'm still curious as to what went wrong though - it's not something I've ever noticed happening before.
