Caja opening Network in dock
For some reason, when I open Caja from the menu, it shows the Network icon in the dock but opens a Caja window. If I pin the Network icon to the dock, close the Caja window, and then click the Network icon directly, it opens a Network window. I checked Caja’s launcher properties in Main Menu preferences, and the command is what it should be – “caja --no-desktop --browser %U.” What else could be causing this? Thanks.
Hi @kawedel,
I’m not sure but you might find an answer here?:
