Camera does not work
Can’t seem to get my Logitech Pro 900 to work. Any suggestions? App opens but doesn’t do anything
Read this -
https://ubuntuforums.org/showthread.php?t=1699930
Perhaps it will help.
  • Which app?
  • What does not do anything mean?
Sorry, app is Cheese. Only a blank window when camera is plugged in. When camera is not plugged in the window is black with the camera icon at bottom grayed out.
Thanks
What version of UM are you using? I ask because I had this problem only last week after installing UM 16.04.2.
I then installed 16.10 to see if the problem persisted and it did.
I then went on-line and got hold of a copy of 16.04.1 and installed that version and my logitech camera is working again. All of which suggests that some changes have been made since UM 16.04.2 that are buggering up the logitech webcam on UM from that point onwards.
I am sure it will get fixed at some point. These things usually are. But, in the meantime, it might be worthwhile simply reinstalling with UM 16.04.1
You can get 16.04.1 here:
http://cdimage.ubuntu.com/ubuntu-mate/releases/16.04/release/ubuntu-mate-16.04.1-desktop-amd64.iso
Or the torrent for 16.04.1 here:
http://cdimage.ubuntu.com/ubuntu-mate/releases/16.04/release/ubuntu-mate-16.04.1-desktop-amd64.iso.torrent
I am running the latest, 17.04 I believe. Thanks for your interest.
My guess, then, is that the problem with the Logitech camera I have identified in 16.04.2 and 16.10 has persisted into 17.04.
