Hello! help me
i have a Notebook hp 14 series with webcam Chicony included
System:
Kernel: 5.4.0-37-generic x86_64 bits: 64
Desktop: MATE 1.24.0 Distro: Ubuntu 20.04 LTS (Focal Fossa)
Machine:
Type: Laptop System: Hewlett-Packard product: HP 14 Notebook PC
Mobo: Hewlett-Packard model: 220F v: 57.58
serial: <superuser/root required> UEFI: Insyde v: F.45 date: 06/27/2018
CPU:
Dual Core: Intel Celeron N2830 type: MCP speed: 1608 MHz
min/max: 500/2416 MHz
Graphics:
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
driver: i915 v: kernel
Display: x11 server: X.Org 1.20.8 driver: modesetting unloaded: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics (BYT) v: 4.2 Mesa 20.0.4
Network:
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter driver: ath9k
Device-2: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
Drives:
Local Storage: total: 704.24 GiB used: 53.71 GiB (7.6%)
Info:
Processes: 208 Uptime: 31m Memory: 7.66 GiB used: 1.69 GiB (22.0%)
Shell: bash inxi: 3.0.38
when i try to start any application (OBS, Teams, Zooms, Crhome Meet, Cheese), the camera start 1 second and turns off.
this happens intermittently but never stabilizes
do you see the camera device in the output of lsusb ?
any output from this, dmesg | grep -i camera
maybe this might help ... http://www.ucview.com/products/linux-client-installation
i tried this
jordany@TEst-PC:~$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 032: ID 04f2:b40e Chicony Electronics Co., Ltd HP Truevision HD camera
Bus 001 Device 027: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 001 Device 003: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
and this
jordany@TEst-PC:~$ dmesg | grep -i camera
[ 8.526826] uvcvideo 1-4:1.0: Entity type for entity Camera 1 was not initialized!
[ 180.181428] uvcvideo 1-4:1.0: Entity type for entity Camera 1 was not initialized!
[ 182.599118] uvcvideo 1-4:1.0: Entity type for entity Camera 1 was not initialized!
[ 185.681877] uvcvideo 1-4:1.0: Entity type for entity Camera 1 was not initialized!
[ 271.119826] uvcvideo 1-4:1.0: Entity type for entity Camera 1 was not initialized!
[ 275.641668] uvcvideo 1-4:1.0: Entity type for entity Camera 1 was not initialized!
[ 280.132037] uvcvideo 1-4:1.0: Entity type for entity Camera 1 was not initialized!
[ 284.682839] uvcvideo 1-4:1.0: Entity type for entity Camera 1 was not initialized!
[ 289.704721] uvcvideo 1-4:1.0: Entity type for entity Camera 1 was not initialized!
[ 294.183728] uvcvideo 1-4:1.0: Entity type for entity Camera 1 was not initialized!
[ 297.886384] uvcvideo 1-4:1.0: Entity type for entity Camera 1 was not initialized!
when I execute install ucview
jordany@TEst-PC:~$ sudo apt-get install ucview
Reading package list ... Done
Creating dependency tree
Reading status information ... Done
Do not can instal some pack. This may mean that
you asked for an impossible situation or, if you are using the distribution
unstable, that some required packages have not yet been created or are
they have taken from "Incoming".
The following information may help resolve the situation:
ucview: Depends: libwebkitgtk-dev but is not installable
Depends: polipo but is not installable
Depends: browser-plugin-vlc but is not installable
E: The problems could not be corrected, you have retained broken packages.
I found some pages that read, this device model 04f2:b40e is known to have problems
(look for type=camera and you will see a yellow triangle with ! )
Thank you
I uninstall Zoom -> update -> upgrade -> reinstall Zoom
now it works!!
