Can Engrampa File Archiver be customized ?
I need it to show file date and time for files to add to archive.
If it can’t be, what about another GUI file archiver ?
Hi @fixit7, I believe you refer to the Add Files dialog box?
I took a look and there's been some changes in this dialog box that are not in 16.04 if this affects you. Particularly Right-Click the column names to add columns like this:
Personally, I setup Caja in list mode to always include date and time. Engrampa can then add files from Caja with drag-n-drop.
Is there a way for it to show date in month/day/year format ?
