I have installed UM 16.10 , dual boot with Win10, and the /boot is on /dev/sda9, root / is on /dev/sda8, no errors get during the installation. Used I use easyBCD on win10 to add an boot entry, it works on UM 16.04(aslo on ubuntu 16.04).
BUT this method does not work on UM 16.10. it get grub>, and I try to use ls command, only got
error 14: FileSystem compatibility error, cannot read the whole file
edit:I found all non-LTS ubuntu have this issue, include ubuntu 16.10,ubuntu gnome 16.10, ubuntu 17.04;
CAN anyone help! thanks
edit: I try the super_grub2_disk tool, it can get into ubuntu and I use boot repair to reinstall grub2, but it DOESN'T work, it can get Grub Boot menu, but can not get into UM system.
