I used dconf editor to change my sleep timeout to 300 seconds when on AC.
But there is no change?
Is the sleep timeout not configurable?
What are outputs of the following commands?
gsettings get org.gnome.settings-daemon.plugins.power sleep-inactive-ac-timeout
gsettings get org.gnome.settings-daemon.plugins.power sleep-inactive-ac-type
Here they are.
300
suspend
Where is the file that contains those settings?
Open dconf
Navigate to org.gnome.settings-daemon.plugins.power
Set the required value Custom value (based on the Description if use 0 => never)
This works on my PC.
And this is set up via Control Center -> Power Management
I have already done that.
It does not work on my system.
Control Power Management only has 10,30 mins, 1 and 2 hrs and never.
