I have a Brother hl-2240 printer.
I am using Ubuntu-mate 16.04.
It does not print a test page or a document.
What can I check ?
What can I check ?
Hi @fixit7,
if you have Synaptic installed, open it and search for “brother” and see what packages are available, mark them all if they aren’t already marked and install them!.
To install via the terminal (Ctrl + Alt + t):
sudo apt-get install synaptic
As I recall, there were a few things I had to do before installing my Brother printer, different model. On the driver download page on the Brother website, there was an easy=to-miss link to a page called something like “pre-installation requirements”. Make sure those are met, otherwise the printer will just not work. { been there
HTH
There weren’t any brother packages that applied to my case.
Thanks for everyone's help.
They had no 2240 driver, but they had 5 drivers for 2140.
I found this one that worked. ![]()
Brother HL-2140 Foomatic/hl1250 (grayscale)
