lsusb shows the DAC
the kernel drivers show loaded
I just cannot get applications, amixer, alsamixer, rhythm box, to see the DAC.
Anyone have any ideas?
Thanks
Phil
lsusb shows the DAC
Thanks
Phil
I have two questions to start with:
alsactl info?inxi -SMAz?couldn't find info
used
pi-mate-29:~(2004)sudo alsactl init
alsa-lib main.c:1412:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -2
Found hardware: "bcm2835_headpho" "Broadcom Mixer" "" "" ""
Hardware is initialized using a generic method
alsa-lib main.c:1412:(snd_use_case_mgr_open) error: failed to import hw:1 use case configuration -2
Found hardware: "vc4-hdmi" "" "" "" ""
alsa-lib main.c:1412:(snd_use_case_mgr_open) error: failed to import hw:2 use case configuration -2
pi-mate-29:~(2005)sudo inxi -SMAz
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LANG = "en_US"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
System:
Kernel: 5.15.0-1075-raspi aarch64 bits: 64 Desktop: MATE
Distro: Ubuntu 22.04.5 LTS (Jammy Jellyfish)
Machine:
Type: ARM System: Raspberry Pi 4 Model B Rev 1.5 details: BCM2835
rev: d03115 serial: <filter>
Audio:
Device-1: bcm2711-hdmi0 driver: vc4_hdmi
Device-2: bcm2711-hdmi1 driver: vc4_hdmi
Device-3: bcm2835-audio driver: bcm2835_audio
Device-4: AudioQuest DragonFly Red type: USB driver: hid-generic,usbhid
Sound Server-1: ALSA v: k5.15.0-1075-raspi running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
pi-mate-29:~(2006)
so inxi can see it! thats good.
alsa cannot. not so good!
Phil
alsactl init won't help anyway, it doesn't list (for example) the USB headset that I'm currently using. You could try arecord --list-devices.
Those drivers look a little bit old, given that alsa-utils doesn't support the 'info' command, and you're sitting on pipewire version 0.3.48 which is from about 3 years back; and a lot has changed over that time.
Two more things that might help me figure out what I'm looking at:
pactl info tell us?wpctl status | grep Devices -A5 should show what devices are known to wireplumber (i.e. pipewire).sorting through things.
I found these two lines in dmesg
[ 12.936853] snd-usb-audio 1-1.3:1.0: cannot find the slot for index 0 (range 0-0), error: -16
[ 12.936904] usb 1-1.3: cannot create card instance 0
[ 12.936919] snd-usb-audio: probe of 1-1.3:1.0 failed with error -16
Don't know exactly what this means (yet) but looks suspiciously like the issue....
PK
i-mate-29:log(2012)pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 102
Tile Size: 65472
User Name: phil
Host Name: pi-mate-29
Server Name: PulseAudio (on PipeWire 0.3.48)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: auto_null
Default Source: auto_null.monitor
Cookie: f40b:2f4d
pi-mate-29:log(2016)wpctl status | grep Devices -A5
├─ Devices:
├─ Sinks:
│ * 33. Dummy Output [vol: 1.00]
├─ Sink endpoints:
├─ Devices:
├─ Sinks:
├─ Sink endpoints:
pi-mate-29:log(2017)
found some references to a similar error. tried a workaround but it still fails to initialize.
Apr 15 02:21:54 pi-mate-29 kernel: [ 1213.671532] usb 1-1.3: USB disconnect, device number 3
Apr 15 02:22:03 pi-mate-29 kernel: [ 1223.165562] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
Apr 15 02:22:03 pi-mate-29 kernel: [ 1223.273210] usb 1-1.3: New USB device found, idVendor=21b4, idProduct=0082, bcdDevice= 1.06
Apr 15 02:22:03 pi-mate-29 kernel: [ 1223.273250] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Apr 15 02:22:03 pi-mate-29 kernel: [ 1223.273267] usb 1-1.3: Product: AudioQuest DragonFly Red v1.0
Apr 15 02:22:03 pi-mate-29 kernel: [ 1223.273281] usb 1-1.3: Manufacturer: AudioQuest
Apr 15 02:22:03 pi-mate-29 kernel: [ 1223.273294] usb 1-1.3: SerialNumber: AQDFRD0100102320
Apr 15 02:22:09 pi-mate-29 kernel: [ 1228.530140] hid-generic 0003:21B4:0082.0002: hiddev0,hidraw0: USB HID v1.11 Device [AudioQuest AudioQuest DragonFly Red v1.0] on usb-0000:01:00.0-1.3/input2
Apr 15 02:22:09 pi-mate-29 mtp-probe: checking bus 1, device 4: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3"
Apr 15 02:22:09 pi-mate-29 mtp-probe: bus: 1, device: 4 was not an MTP device
Apr 15 02:22:09 pi-mate-29 kernel: [ 1228.579804] snd-usb-audio 1-1.3:1.0: cannot find the slot for index 0 (range 0-2), error: -16
Apr 15 02:22:09 pi-mate-29 kernel: [ 1228.579833] usb 1-1.3: cannot create card instance 0
Apr 15 02:22:09 pi-mate-29 kernel: [ 1228.579845] snd-usb-audio: probe of 1-1.3:1.0 failed with error -16
Apr 15 02:22:09 pi-mate-29 kernel: [ 1228.581300] usbcore: registered new interface driver snd-usb-audio
Looks like, perhaps, an incorrect setting for modprobe?
The output of grep -r 'index=' /etc/modprobe.d might help; here's what it looks like on my UM24.04 machine (defaults):
/etc/modprobe.d/alsa-base.conf:options bt87x index=-2
/etc/modprobe.d/alsa-base.conf:options cx88_alsa index=-2
/etc/modprobe.d/alsa-base.conf:options saa7134-alsa index=-2
/etc/modprobe.d/alsa-base.conf:options snd-atiixp-modem index=-2
/etc/modprobe.d/alsa-base.conf:options snd-intel8x0m index=-2
/etc/modprobe.d/alsa-base.conf:options snd-via82xx-modem index=-2
/etc/modprobe.d/alsa-base.conf:options snd-usb-audio index=-2
/etc/modprobe.d/alsa-base.conf:options snd-usb-caiaq index=-2
/etc/modprobe.d/alsa-base.conf:options snd-usb-ua101 index=-2
/etc/modprobe.d/alsa-base.conf:options snd-usb-us122l index=-2
/etc/modprobe.d/alsa-base.conf:options snd-usb-usx2y index=-2
/etc/modprobe.d/alsa-base.conf:options snd-pcsp index=-2
Oh, also grep -r 'index=' /lib/modprobe.d might be useful.
By the way; this is telling us that the snd-usb-audio driver is not being loaded; which means something is failing on the kernel level (i.e. potentially incorrect settings).
As an example of what we want to see; here's the output given a USB headset connected to my system:
Device-5: Razer USA Barracuda X driver: hid-generic,snd-usb-audio,usbhid
type: USB
Did you find a solution @pjkemp ?
