I have seen Change keyboard and keep it - but that did not help.
I have (via mate-about) Mate 1.24.0 on:
$ cat /etc/issue
Ubuntu 20.04.2 LTS \n \l
Unfortunately, since:
Sorry, new users can only put one embedded media item in a post.
Sorry, new users can only put 2 links in a post.
... all of my work putting screenshots has now been wasted (why not put out an alert the very moment I paste one link more than my quota is, ffs?), so here is the link to the post with all images on imgur (not sure why it gets shown as an image - just click on it, all of the images should be in this post):
Here is what I've tried:
First, I reset
dconfusingdconf reset -f /Note, as shown on the screenshot, that after this, the OS recognizes English as "language for menus and windows", but Danish as default keyboard layout (most likely, because I had to specify Danish keyboard during installation from USB stick, because that is the kind of keyboard I had):
i.imgur .com/klOrLy6m.png
Then, I add the US english keyboard layout:
i.imgur .com/EZzTjGsm.png
Double-check: Keyboard Preferences now shows the added US English keyboard layout as second. Then, I select the Danish keyboard layout and remove it:
i.imgur .com/1H4ieTlm.png
Log out from the system:
i.imgur .com/JukoOmlm.png
Log back in again - since US English should be the only keyboard layout right now, it is the default, as expected. Then I again add the Danish keyboard layout as second one - hoping that the US English keyboard layout, as first, will be the default one:
i.imgur .com/Q3F7oG1m.png
Log out again:
i.imgur .com/YsoXyQbm.png
Now, let's focus on the login screen at this time - on this screen, at this time, the default keyboard layout is Danish!:
i.imgur .com/yQ3uXjLm.png
Now that I log in back again, the default keyboard layout is unfortunately still Danish, even if I wanted the US English one to be the default:
i.imgur .com/Y7pyIwSm.png
Finally, I decide to test the "Use default option" in
gconf-editor- once I do that, the additional (actually, all) keyboard layouts from "Custom value" are deleted - so after that, I could not even change to US English keyboard layout manually!:i.imgur .com/y0VUfyam.png
So: how can I set up Mate, so that US English is my default keyboard layout -- and that persist across logout/logins and reboots, -- even if I have Danish as a second keyboard layout?
