its been a while since ive asked anything on here mainly because i’ve had no troubles and am finding mate 15.04 to be great.
However i have been using a usb cable to connect to my printer but as its wireless i should really just connect it wirelessly!
The problem i have is that i’m not sure how to do this…I have connected the printer to my home wifi network but when i try to find it on my laptop it asks me for a host address. Im not sure what this is or how i can find it so any help/advice would be gratefully received
This sounds like you're looking for the IP address of your printer. If you're not sure what this is, it's a unique address assigned to each device connected to the network. Quite often they look like this: 192.168.1.1, 192.168.1.2, 192.168.1.3 etc. Not all networks follow that pattern.
Usually the Add Printer dialog shows a list of printers found on the network, listed here where this red line is pointing:
If not, we can determine the address of the printer a few ways.
Some routers allow you to connect to their web page to also list them, try http://192.168.1.1 - or check the Network Applet in the top-right and choose "Connection Information" and try the "Default Route" address.
The other way is to use nmap which finds LAN neighbours on the network.
