im new to raspberry pi and ubuntu please help
Hi @dwm,
you need to tell everyone what you have tried thus far please?: Is your network (LAN) working?.
Hi There,
I had the same problem with the Pi3,
Check your Router config,
My ZyXEL / VMG8324-B10A router has the bandwith on 40 MHz by default.
After changing it to 20 MHz the SSID was visible to the Pi3 wifi adapter to and it works perfect now.
i’ll hope this will fix your problem.
Kind Regards
