Forgive my noobness, but I haven’t been able to get apt-get to install fuseext2. I get “unable to locate package fuseext2”.
I’ve checked download location in Software & Updated (it’s Main Server), and universe and main are both checked.
Any suggestions? Thanks
Sadly, this package is not avaliable for Raspberry Pi (armhf
$ rmadison fuseext2
fuseext2 | 0.3-1 | precise/universe | amd64, i386, powerpc
fuseext2 | 0.4-1.1 | trusty/universe | amd64, i386, powerpc
fuseext2 | 0.4-1.1 | vivid/universe | amd64, i386, powerpc
fuseext2 | 0.4-1.1 | wily/universe | amd64, i386, powerpc
fuseext2 | 0.4-1.1 | xenial/universe | amd64, i386, powerpc
fuseext2 | 0.4-1.1 | yakkety/universe | amd64, i386, powerpc
Instead, this will need compiling from source code, assuming it is compatible with the Raspberry Pi.
First, download a copy of this repository.
Install the build tools:
sudo apt install build-essential
Then the dependencies for building:
sudo apt install m4 autoconf automake libtool
sudo apt install libfuse-dev e2fslibs-dev
Then compile it:
./autogen.sh
./configure
make
sudo make install
See their README for more information. I haven’t used this package or compiled it from scratch.
Good luck!
