I’ve got UM 16.04 installed on my RPI 3B. Almost everything is working great, but I’m having trouble doing some things on the desktop when logged in to my admin account over VNC. In particular, I cannot change most settings, run Synaptic or mount drives from the GUI. Some applications will not even open. With some apps (such as Synaptic) opening them from Terminal using gksudo helps; for others it does not. Even when some settings apps (such as Users & Groups or Networks) open, I cannot change many settings or click on any of the advanced settings buttons. In Networks, pressing the Unlock button does not even open the password dialog.
I am using TightVNC over an SSH tunnel. TightVNC is running under the same user account I am logged in under. If it matters, I’ve set that user account to automatically login to at startup.
