Hello everybody.
I can't open the control center on my machine. I've just upgraded to 20.04, but since the 19.10 this problem exists.
Can't find a solution. Does anybody ever seen this problem? Screenshot below:
Hello everybody.
The Control Center appears under the System menu (3rd icon) (Traditional panel layout)
in Familiar, it appears at the bottom of Menu)
Yes, but it doesn't work, so I call the executable from the terminal to see any error messages (screenshot).
Thanks for your reply.
Can you please create a bug report on: mate-control-center
If you don't know how to, this walk you through: How to report problems in Ubuntu Mate
I'm having lots of weird issues, things that install but don't work but then does after a reboot.
Control center doesn't scroll on a fresh install (done it twice) the first time its run until the window is resized. Then it seems to work fine afterwards. How can you file a bug report on something like this?
Taking notes on this second install, but Mate 20.04 is showing the kind of "fixes itself after reboot" that I thought I'd left behind with Windows
This laptop ran 16.04 for over a year with only one issue -- the installer didn't recognize its trackpad so I had to use and USB mouse, but trackpad worked fine on installation first boot.
For example, Pithos installed from the Boutique didn't work until I rebooted
This is just not the Linux way things are supposed to be!
Just did that. Thank you.
