Hi
I have a HP office jet 5200 and have noticed that I can't print multiple copies.
Wondered if anyone else has experienced this
Thanks
Hi
Thanks
Hi kappicraig,
Try to disable Collate Option.
Hope it helps you.
Thanks Tim,
I don't think it's that. If I have a one page doc and wish to print several copies then the collate option is naturally greyed out.
Thanks for the feedback though
Hi
Have you try to remove the printer and add it again ?
Maybe something went wrong during the configuration.
Supposedly that is driver & printer compatibility matter. I.e. number of copies is incorrectly transmitted to the printer and/or is not correctly understood by the printer.
Have you tried to install native HP drivers for Linux?
https://support.hp.com/us-en/document/c01174360
Yeah I did thanks. Tried but ended up with terminal text all red and I don't think the hplib installed at all
Thanks
Still getting this problem. Has anyone else experienced this at all?
Thanks
Hi kappicraig,
I was having same problem some years ago with an epson printer. No manner of print more than 4 pag at time. Drivers issue.
You can try with this article. Perhaps give you any idea.
