Ubuntu MATE 15.10 64-bit, MATE 1.10.2, Kernel Linux 4.2.0-27.
When i try to run gpointing-device-settings i get this:
Segmentation fault (core dumped)
Was trying the same on a Xubuntu 15.10 32-bit in VirtualBox, no problem there.
Can someone help please? I need to configure my touchpad.
try running the following terminal command (Ctrl + Alt + t) and restart if anything updates:
sudo apt-get install -f
Nothing
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
