Hi can anyone tell me how to see what wifi networks are in range ?
Try looking in additional drivers, see if wifi driver is installed, looks as if it is not?
Hi
Please provide the output for the following command run in a terminal (Open terminal using CTRL+ALT+T)
lshw -C network
*-network
description: Wireless interface
product: AR9485 Wireless Network Adapter
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlp2s0
version: 01
serial: 50:b7:c3:15:4d:f3
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list rom ethernet physical wireless
configuration: broadcast=yes driver=ath9k driverversion=4.4.0-36-generic firmware=N/A ip=192.168.0.102 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
resources: irq:16 memory:db500000-db57ffff memory:db580000-db58ffff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:03:00.0
logical name: enp3s0
version: 06
serial: e8:03:9a:e0:e0:7c
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168e-3_0.0.4 03/27/12 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
resources: irq:26 ioport:2000(size=256) memory:db404000-db404fff memory:db400000-db403fff
problem solved it self after restart
