I am attempting to use the PPA version of touchegg on the Raspberry Pi version of MATE. The PPA is at version 2.0+ while Ubuntu Universe is at 1.1+.
The PPA info is here: Packages in “Touchégg - Stable PPA - Official Releases” : Touchégg - Stable PPA - Official Releases : “Touchégg” team
I execute: sudo add-apt-repository ppa:touchegg/stable
and the PPA appears to install. This is followed by apt-get update
/etc/apt/sources.list.d/touchegg-ubuntu-stable-focal.list contains
deb http http://ppa.launchpad.net/touchegg/stable/ubuntu focal main
I also placed 99-touchegg-repository in /etc/apt/preferences.d ; it contains
Package: touchegg
Pin: release o=LP-PPA-touchegg
Pin-priority: 450
However, "apt policy touchegg" still shows that the only version of touchegg available is that in universe.
How do I get apt within MATE to use the version of touchegg in the PPA?
Welcome to Ubuntu MATE community!
You are doing all the steps correctly. The problem here is that PPA provides packages only for amd64 CPU architecture. See PPA file-listing for confirmation.
I wrote a message to “Touchégg” team on launchpad with request for armhf and arm64 package builds. Let's wait for reaction.
If you are in hurry - download official packages from GitHub by using commands below:
cd ~/Downloads
# for arm64
wget -c https://github.com/JoseExposito/touchegg/releases/download/2.0.11/touchegg_2.0.11_arm64.deb
sudo apt-get install ./touchegg_2.0.11_arm64.deb
# for armhf
wget -c https://github.com/JoseExposito/touchegg/releases/download/2.0.11/touchegg_2.0.11_armhf.deb
sudo apt-get install ./touchegg_2.0.11_armhf.deb
Or compile this package manually directly on RaspberryPi. At first enable source code (deb-src repositories) in Software and Updates, then execute commands below:
sudo apt-get update
sudo apt-get build-dep touchegg
sudo apt-get install git build-essential cmake libcairo2-dev libgtk-3-dev libinput-dev libpugixml-dev libudev-dev libxrandr-dev
cd ~/Downloads
git clone https://github.com/JoseExposito/touchegg.git -b 2.0.11
cd touchegg
dpkg-buildpackage -uc -us
sudo apt-get install ../touchegg_2.0.11_arm*.deb
Thanks. That completely makes sense.
Compiled and the software executes. Unfortunately, it doesn't seem to detect any gestures. Time for more debugging.
