I finished a book and it uses a large print font called Centerpoint.
I did a search but found nothing.
I would like to install that font.
Hello @fixit7
The most funny will be searching the font on the internet. If it is on a web page, you can get into development mode (mostly F12 key) and try to find the font url.
Once you downloaded it, double click > install font and here we are
