Change default window manager using dconf editor
I'm trying to change the default window manager to awesome using dconf-editor. I'm on ubuntu mate 18.04 and I can't see default values under org/mate/desktop/session/required-components-list.
I really appropriate if someone can help me with this.
If you have awesomewm installed, you can change to it from the login screen.
