Change icon for ups battery on panel
Is there any way to change the icon for the UPS battery icon on the panel ? (power management preference)
HI @fixit7,
it would be wholly dependent on what icon theme you are using I would think???. :smiley:
I saw that I can change my icon theme. However I would prefer just changing one icon.
I assume that you would have to get into the icon folder where the set is located and replace it with a different one but I don’t know how to do that sorry!. :frowning:
I looked at all the battery icons, but none looked like the right one.
No big deal. :slight_smile:
