I need help in setting my monitor resolution. Please keep it brief.
I have been away for 5 months.
Thanks,
Andy
Thanks,
Andy
The first place to try should be System then Preferences then hardware then displays. You can also find it in the control center in the hardware section. Hope this helps.
