Is there a way to change the color of the Plank (DOCK) and or the transparency?
Hi
Yes you can.
Just look for Plank themes (you can edit them according to your tastes as well) and put them in ~/.local/share/plank/themes then you will find them in the plank preferences.
Thank you figured it out. Working great.
You can change plank theme in plank preferences
Thank you I couldn't find the app. But I looked and looked and found it sitting in the dock.
