This script sets the top panel to full transparency if no maximized window is on the current workspace.
Sort of like Dynamic Transparency with budgie-panel’s in Solus.
Whenever there is a maximized window on a workspace the top panel will turn off transparency.
- The only issue is that clock applet opacity isn’t changing.
Save, make executable, run on startup
#!/bin/bash
# Requires: xprop
# Adjust values to suit
PANEL=top
PANEL_ALPHA_REGULAR=0
PANEL_ALPHA_MAXIMUM=1
# don't change anything below here
gsettings set org.mate.panel.toplevel.background:/org/mate/panel/toplevels/top/background/ type "color"
CURR=0
while true
do
MAX_FND=0
for w in $(xprop -notype -root _NET_CLIENT_LIST 2>/dev/null | cut -d'#' -f2 | tr ',' '\n' | awk '{print $1}')
do
if [[ "$(xprop -id $w -notype _NET_WM_DESKTOP 2>/dev/null | cut -d' ' -f3)" -eq "$(xprop -root -notype _NET_CURRENT_DESKTOP 2>/dev/null | cut -d' ' -f3)" ]]
then
if xprop -id $w _NET_WM_STATE | grep -E "MAXIMIZED_HORZ.*MAXIMIZED_VERT" > /dev/null 2>&1
then
if xprop -id $w WM_STATE | grep -E "window state: Normal" > /dev/null 2>&1
then
MAX_FND=1
break
fi
fi
fi
done
if [[ $MAX_FND -eq 1 && $CURR -eq 0 ]]
then
gsettings set org.mate.panel.toplevel.background:/org/mate/panel/toplevels/${PANEL}/background/ color "rgba(60,59,55,$PANEL_ALPHA_MAXIMUM)"
CURR=1
elif [[ $MAX_FND -eq 0 && $CURR -eq 1 ]]
then
gsettings set org.mate.panel.toplevel.background:/org/mate/panel/toplevels/${PANEL}/background/ color "rgba(60,59,55,$PANEL_ALPHA_REGULAR)"
CURR=0
fi
sleep 1
done
exit 0
