Hi
A second problem I have is that I have connected an amp to the raspberi pi that I have connected basic speakers to. When I run the raspberi pi at the moment, it is connected to my main pc screen with a HDMI cable.
The sound on the Pi automatically defaults to go through my screen and I don’t appear to have an option to adjust the sound output on the pi to go through the amp and not the hdmi. When I used Raspbian Jesse, there was an option to change the output of the sound.
Would you know how I would change the pi with Mate to ignore the hdmi sound and default to an external amp output.
Kind Regards
Ian
