I made a script to easily change the wallpaper of the loginscreen.
It lets the user select an image and set it as the desktop background on Ubuntu MATE. It copies the image to the /usr/share/backgrounds directory, updates the background setting, and recompiles the schemas.
#!/bin/bash
# This script lets the user select an image and
# set it as the desktop background on Ubuntu MATE. It copies
# the image to the /usr/share/backgrounds directory,
# updates the background setting, and recompiles the schemas.
# Philippe734 @ 2025
# Check if YAD installed
if ! command -v yad &> /dev/null; then
pkexec bash -c "apt install yad -y"
fi
yad --title="Change background login screen" --height=150 --width=400 --fixed --text="<span foreground='blue'><b><big><big>Select your image</big></big></b></span>" --text-align=center --center --borders=20 --image='./design.png'
if [ $? = 1 ]; then
echo "canceled"
exit 0
fi
DEST_DIR="/usr/share/backgrounds"
SCHEMA_FILE="/usr/share/glib-2.0/schemas/30_ubuntu-mate.gschema.override"
while true; do
# Let the user select an image
IMAGE_PATH=$(yad --file --center --title="Select an image" --width=600 --height=400)
# If no image is selected, exit
test -z "$IMAGE_PATH" && exit 1
# Check if the selected file is an image
MIME_TYPE=$(file --mime-type -b "$IMAGE_PATH")
if [[ $MIME_TYPE =~ ^image/ ]]; then
break # Exit the loop if the file is a valid image
else
yad --title "Error" --width=400 --height=100 --center --button=OK:0 \
--text "The selected file is not an image. Please select a valid image file."
fi
done
# Get the file name without modification
IMAGE_NAME=$(basename "$IMAGE_PATH")
# Final path in /usr/share/backgrounds
FINAL_IMAGE_PATH="$DEST_DIR/$IMAGE_NAME"
# Escape the apostrophes in the image path before running pkexec
ESCAPED_IMAGE_PATH=$(echo "$FINAL_IMAGE_PATH" | sed "s/'/'\\\\''/g")
# Call pkexec to execute commands as root
pkexec bash -c "
# Copy the image and modify the schema
cp -f \"$IMAGE_PATH\" \"$FINAL_IMAGE_PATH\"
# Change permissions of the copied image to make it readable by others
chmod 644 "$FINAL_IMAGE_PATH"
# Modify the schema file to set the new background image path
sed -i \"s|^background=.*|background='$ESCAPED_IMAGE_PATH'|\" \"$SCHEMA_FILE\"
# Compile the schemas
glib-compile-schemas /usr/share/glib-2.0/schemas/
# Display the final result
echo "### result:"
grep "^background=" "$SCHEMA_FILE"
echo "###"
notify-send "Done" "You should logout"
exit 0
