I use a layout similar to the “Familiar” template on MATE Tweaks. I’ve noticed that the panel on the top of my screen has been acting a bit strange. In the past, it would show a clock in the top right, and I could click it to see my calendar information. For some reason, now, it is gone. For reference, this is how it looks now on the top right of my screen:
No clock; though, I do see it appear briefly during startup then it disappears. I’ve temporarily been adding the clock to the panel by right clicking and selecting “Add to Panel” but this clock behaves differently than the previous one, and also I cannot put it in the top right of my screen like I prefer. This is what it currently looks like on the top left of my screen:
Does anyone know how I can return the “default” clock back to the panel?
This is odd but my Indicator Applet Complete shows neither time nor date! I tried removing it and re-adding it (because it seems to be the correct indicator in every other way). I tried restarting just in case too.
What I didn’t realize before was that the indicator was “locked.” Now that I have it unlocked I’ll be using @ericmarceau ‘s suggestion of moving a separate clock Applet to be adjacent to the Indicator applet (for me I like it being to the right side of the indicators).
Very strange that the clock just vanished from the Indicator Applet Complete; it disappeared out of the blue a day or two ago; I don’t know what I did.
PS Thanks for the suggestion to create a named layout I will definitely be doing that.
Also thanks both of you for being so helpful with such a silly question
Oh I just remembered one more thing. The unfortunate thing about the Clock applet is that it doesn’t connect with Evolution, which I have been using for my calendar. On the other hand, when my Indicator Applet Complete had the time on it, I could click that and see upcoming calendar information. I don’t know if there is another way to replicate such behavior.
My system default format string for this last one, custom-time-format, is
%l:%M %p
giving "8:52 PM".
For something like ... 20:44 _ Fri Aug 15 ... the format string needs to be changed to
%R _ %a %b %d
NOTE: I did all that, but it had no effect, even when I toggled "Use system default" to OFF! Also, modifying the time-format parameter had no impact either.
Don't know if those are supposed to have relevance or not but, given they are specific to ayatana, I expected them to have some!
What my test instances for the Apps are currently showing:
For the linkage with Evolution, there was a previously reported issue which may be relevant to what you are experiencing.
Wow! Ok you hit the nail on the head. I went into Evolution, deleted a single task I had that had no start date (only an end date), then restarted my computer. The time is back! And I can click it and it shows calendar information once again. I learned a lesson that I should do a search before asking a question, I don’t know why I didn’t do that.
It is interesting to see your experience experimenting with ayatana configurations. Good to know that customization is hard or impossible in this specific circumstance.
I appreciate all the help. If I have time I’ll look into maybe writing up an issue report.
